hello
Is there a way to connect arena to premiere?the simpliest thinh, to rout the utput of one to the input of the other?
thank you
premiere pro connection
stefanocps
tijnisfijn
- Team Resolume
Re: premiere pro conncetion
May I ask what you are trying to accomplish? You could output the output from arena as NDI, syphon or spout stream, in theory Premier could see that as a camera input. But what would you like to do with that?
stefanocps
basically i want to build my sequence in premiere timeline, and then having part of it processed in resolume
tijnisfijn
- Team Resolume
As I suggested above is probably possible to use a stream for that, but I would think it's probably less processor intensive to render out your premiere file open it in arena, rent it out in arena and back to Premiere again.
Hope this helps and you figure it out...
stefanocps
yes, but i don't like too much. I woud like to be able to edit on the fly what i want. If i have to render all the time i need to change something it becomes a very long process
Re: premiere pro connection
https://ndi.video/tools/premiere-pro-plugin/ Seems like it can send premiere to NDI, so you could NDI capture in resolume and do live effects over that
stefanocps
yes i have tried it, but it looks like it doesn't work with latest premiere. I have tried it on anolder version andsomethign is working..did not go deeply yet, but in the latest version signal form premer seems to do no go out
Sounds like an issue for Adobe. Good luck getting in touch with Adobe, I stopped using their products 2 years ago because they are buggy and don't reply to tech support questions.
stefanocps
i am not so negatve with adobe. I have used it for years and years and i never find it so buggy as some people claim is. I never had t contact support though, but in the adobe forum i have always found solutions.
That said, now i want to go more in experimetal direction and, don't know why, when i try davinci i suddendl find to do inspring thing in this sense. Probably the fx are more interesting for creating things. But when yesterday i gave a look to fusion and i saw how the creation or a simple vfx is simplified and integrated in the timeline...then i said yes. I must go this way. I find davinci resolve more inspiring for experimental video art; may be just because it is a new things for me. Of course i am bit scared to learn this new sw also. Recently i have switched form cubase to Ableton, now switch from premiere to resolve, while learning arena...a lots of work, and i don't have so much time to invest
Let's see..
By the way what about arena and davinci integration? i did notfind anything searching in google
Let's see..
I've been using Adobe since about 1998, Last project had 18 crashes in 2 hours, and all I was doing was simple compositing in premiere. They also changed "standardized" shortcuts such as how to save in photoshop. The only product worthwhile for me is AE and LR classic. I've moved on to Resolve and Affinity and haven't looked back.
But enough of my ted talk haha.
I have never had to bring Arena into a compositing software before, however I have brought AE into arena and that worked really well with NDI.
