Hello using the showsync ml4 plugin to control resolume via ableton
I need to know if there are more path available to those that are like "preset" in the parameter forwarding device
There are preset to go to composition and scene..and they work fine
I want to control some parameters of the CLIP..i have tried some combination for the this path but i coudnot get it to work
Can you help with this?
thanks a lot!
correct path for osc
tijnisfijn
- Team Resolume
Re: correct path for osc
Almost every function, option and button in arena has a OSC address. You can find them by going to shortcuts/edit OSC in the top menu. or the shortcut Shift-Command(Control)-O. click on the thing that you would like to control and look in the shortcut window for the right address.
Here is some more information. https://resolume.com/support/en/osc
Good luck. I hope you figure it out.
