DMX bugs
JohnnyMauser
DMX bugs
Post by JohnnyMauser »
Dear Resolumees,
I found DMX in Resolume to be a little buggy. I use DMX via Art-net via a Kissbox. In other software it works as expected.
# I have some dirty signal in my DMX universe, i don't know where that is coming from, but when i enter the "Edit DMX" Tab, the automaticaly active learning stage is messing up my allready made triggers.
-> it would be nice when the "learning function" could be toggled like in other software. On resolume the only workaround i found is to delete the universe in the settings before i enter "edit DMX"
# The DMX Monitor seems to be buggy. I have a signal which shows in the monitor, than i disconnect the cable, but the signal is still showing i have to reopen the monitor
# I have a signal of lets say channel 183 value 255 and trigger a column with that, which works. But after a few seconds the detected signal (also in the monitor) jumps back to 0, and than a few seconds later is triggered again. This happens in the composition as well as Monitor
I am on Windows 10 and Resolume 7.20.1 rev35767
cheers,
-johnny-
Re: DMX bugs
Any other apps running on the machine which might send DMX?
Do you still see input after disabling Resolume outputs, and disconnecting cables?
JohnnyMauser
Re: DMX bugs
yeah, sometimes the input is still visible in the monitor, even though the cable is pulled. Closing and opening the resolume monitor is fixing the problem.
Re: DMX bugs
Do you mean you see the monitor keeping the last values received?
That's how it should be, so you can see what came in.
avclubvids
Re: DMX bugs
Post by avclubvids »
I had an issue where Universe 0 was not working reliably, we never found it but we suspect that something on the network was broadcasting on that universe. Try using Universe 1 or another to see if things stabilize?
