Render Passes
cat
Render Passes
Post by cat »
I still haven't got my head around render passes in glsl it seems.
I am trying to downsample an image in steps of 1/2 each time, this shader gives no errors, but doesnt output anything.
also does $WIDTH mean the previous render pass size or the original input size? should it be $WIDTH/2 , $WIDTH/4 etc?
Is there any way of getting point sampling rather than linear?
Code: Select all
    "CREDIT": "",
    "DESCRIPTION": "",
    "CATEGORIES": [ "generator" ],
    "INPUTS": [
            "TYPE": "image",
            "NAME": "tex0",
	"PASSES": [
	    "TARGET" : "pass0",
		"TARGET" : "pass1",
      "WIDTH": "$WIDTH/2",
	  "HEIGHT": "$HEIGHT/2"
		"TARGET" : "pass2",
void main() {
	//vec2 uv =  isf_FragNormCoord.xy ;
	if (PASSINDEX == 0)
	    vec4 col = IMG_NORM_PIXEL(tex0, isf_FragNormCoord );
        gl_FragColor = col;
	if (PASSINDEX == 1){
		gl_FragColor =  IMG_NORM_PIXEL(pass0, isf_FragNormCoord );
	else{
		gl_FragColor =  IMG_NORM_PIXEL(pass1, isf_FragNormCoord );
dtristram
Re: Render Passes
Post by dtristram »
has anyone succeeded in reading multiple buffers in different passes? I don't believe it works.
cat
Re: Render Passes
Post by cat »
I have, but it didn't feel logical to me
"PASSES":
"TARGET": "P01",
"FLOAT": true
"TARGET": "P02",
"FLOAT": true
accessed by
some code here
ie setup some floats vec2's
if (PASSINDEX == 0) {
process1 }
if (PASSINDEX == 2) {
process the output of process1
Shouldn't we be targeting via process name? It seems not, just its pass number
index 0 seems to work in that manner, ie 0 is pass one, thats fine, but pass 2 is accessed by part of the name, or suddenly counting from 1 not zero, I don't get it. I gave up after this point and used separate shaders.
dtristram
Re: Render Passes
Post by dtristram »
$WIDTH is always (for every pass) the width of the input texture so we have to use $WIDTH/2 and $WIDTH/4 to do the subsequent downsampling.
dtristram
Re: Render Passes
Post by dtristram »
I was having trouble, running into a bug where subsequent passes could not read from the target of pass 0. Making target 0 "PERSISTENT": true fixed that problem. more investigations to come...
