Laptop with Radeon 9000
hendrik@studiomuscle.com_
Post by hendrik@studiomuscle.com_ »
As I am loving resolume i would like to take it to the live shows i am doing. So far for live shows I have allways used vjamm pro but am now looking to make the change over.
One question however...i am planning to buy new laptops since the old ones are well old....
I have the option f buying Athlon XP 2000 with a radeon 9000 card and tv out. Since they support directX pretty good I assume they are as worthy as a gforce MX card?
Desktops are not an option since i travel arounf too much
cheers
hendrik
tha radeon card seem to have a better tv-out then the geforce cards so i guess this is a good option, if you have the possibility to upgrade that harddrive to a 5400rpm version you will also gain some speed!
