I was working on a shader to do SDF things with the wire point inputs
I was editing the for loops and then it crashed (as it seems to do a lot)
Now, I cannot open the project at all, just an immediate crash.
The project folder is attached.
Crash on opening Wire project containing ISF shader
- optiphonic
- Attachments
- pointRings.zip
- (6.61 KiB) Downloaded 287 times
Re: Crash on opening Wire project containing ISF shader
Changed from i++ to j++ to avoid infinite loop, should at least open without crashing now.
- Attachments
- pointRings.isf.zip
- (2.51 KiB) Downloaded 280 times
youtube.com/@selfimageprodukts
- optiphonic
Haha true. Thanks! I'm suprised that incorrect shader code crashes wire, thought I must have screwed up something else.sipsipsips wrote: Sat Jul 06, 2024 18:06 Changed from i++ to j++ to avoid infinite loop, should at least open without crashing now.
- optiphonic
Heres the working version, thought it was only fair since you helpedsipsipsips wrote: Sat Jul 06, 2024 18:06 Changed from i++ to j++ to avoid infinite loop, should at least open without crashing now.
- Attachments
- pointRings.zip
- (8.01 KiB) Downloaded 261 times
Accidentally rewritten code can crash not only Wire but other software as well. It's just a matter of opening it in a regular text editor and rewriting the relevant part without rushing, though. Anyway, glad it's fixed!
