What Contrller is this?
jimib007
Post by jimib007 »
On the Resolume home page (splash page?). If you scroll down to "Introducing Resolume Wire" there is a video. Right after the start of the video an artist manipulates the screen through Resolume or Wire using a x-y type controller pad it looks like it is screen based not hardware (iPad?). I Attached screen shot.
Thanks in Advance, Jim
Jim Branstetter
Alienware M17 R4 RTX 3070 Windoze 11
tijnisfijn
Re: What Contrller is this?
Post by tijnisfijn »
What do you see in the picture is probably TouchOSC.
https://hexler.net/touchosc
A really nice app for your iPad that lets you build your own custom controllers.
One recommendation I can give you.... if you wanna use this in live situations always connect your iPad through a cable or ethernet with your computer instead of a wireless network. This will save you a lot of problems.
I hope this helps you out. If you have any more questions don't hesitate to ask.
MarkyMark
Post by MarkyMark »
Tijn is right, this was an Ipad running TouchOSC.
It was the first thing I've ever made in TouchOSC so you should be able to do much more with it than I did for that video.
Would be pretty cool to do an TouchOSC tutorial though!
jimib007
Post by jimib007 »
Thanks for the answers! :D :D :D
Jim Branstetter
