DMX control
Kenjiro
DMX control
Post by Kenjiro »
I am preparing to control Chamsys MQ70 using art-net.
It is generally working without any problems, but
Trigger Clip
Play Head
Play Mode
only does not return to the default value when released.
Even if I play a cue, it sometimes does not return to the set value.
Is there any special setting method?
Re: DMX control
How do you release it?
Are you sending the 0 on the dmx channel?
Kenjiro
Re: DMX control
Post by Kenjiro »
Regarding the Clip value, I released it and sent DMX 000, but it wasn't recognized, so I changed the default value to 001 and it started working properly.
I decided to set the Play Mode and Play Head on the Clip side.
