FreeFrame (FFGL) Plugin Directories not remembered
seethings
Post by seethings »
When I designate a folder for FreeFrame (FFGL) Plugin Directories in the preferences, it disappears the next time I open Resolume. v7.21. Mac Sonoma. M1MaxPro
I've tried adding 3rd party FFGL 2.5 plugins to the Extra Effects folder and the Library/Graphics/FreeFrame Plug-Ins to no avail. Please help.
-Tim
Re: FreeFrame (FFGL) Plugin Directories not remembered
Does Resolume have permissions to write to the disk /documents folder in the privacy settings?
seethings wrote: Wed Jul 10, 2024 20:24 I've tried adding 3rd party FFGL 2.5 plugins to the Extra Effects folder and the Library/Graphics/FreeFrame Plug-Ins to no avail.
Are you using ARM compiled effects?
seethings
Post by seethings »
It is my suspicion that they are not ARM compiled. Is there a method to determine if so?
What does the Resolume log file say about them?
You can open it from preferences - feedback tab
seethings
Post by seethings »
The issue seems to be fixed in v7.21.2 rev37990.
I assigned different folders, Quit Arena, and the newly added folders remain. Checking the Log file, it does not seem to log the adding of FFGL folders.
Thank you,
-Seethings
