Crossfading with DMX
Kenjiro
Post by Kenjiro »
It is controlled by DMX.
When crossfading between layers using each layer's Master fader, it goes completely white once and then crossfades.
When I set Ppacity to 50%, it sometimes crosses over nicely, is this due to the Transition settings?
Re: Crossfading with DMX
Change your blend mode.
Kenjiro
Post by Kenjiro »
Thank you for the information.
Changing the composite Blend Mode made no difference, but changing the Mode of each layer to Alpha solved the problem!
It's now just how I wanted it.
Thank you.
That was helpful!
Yeah layer blend mode to alpha will show full white at 50% most of the time. Alpha should get you what you're after.
