Persistant clips not triggerable after reopening showfile
fldvt
Post by fldvt »
Hey there,
I might have found a bug. (Arena 7.21.2 rev37990)
The environment: In my showfile there are two layers of persistant clips. That means, regardless of the deck I'm in, I always have these clips on my screen to be able to play them.
When reopening the (already opened) Compositon (clicking Composition -> open recent -> my_showfile) the persistant clips are loaded and can be previewed but I can't activate them, I can't play them. All other clips are playable.
Greetings
Lars
Using Arena and Wire for all kind of fun stuff (since early 2023).
Often using ArtNet, OSC or Midi control.
tijnisfijn
Re: Persistant clips not triggerable after reopening showfile
Post by tijnisfijn »
Thank you for noticing this! This is indeed a bug, and I made a issue for it.. Of course, is not what you want but as a workaround, if you open a other composition, and then go back to your original, the Persistant clips will play again.
