cxcore096.dll was not found
rayv
Post by rayv »
i got the following msg when starting the app:
"cxcore096.dll was not found"
another thing is that i cant open all the decks window.
hope to hear from u soon
thanks
[Edited on 28-7-2006 by bart]
LudikaStyle
Post by LudikaStyle »
You are probably using some freeframe plugins that need the OpenCV libraries (.dll). If some decks were set up with those plugins on the clips maybe you won't be able to load them. try and copy the corresponding .dll to the resolume root folder. If you don't know where to get it you should probably remove those freeframe plugins or read their documentation.
my 2 cents
resolume does not use a cxcore096.dll so it,s indeed probably a freeframe plugin that you installed that is missing this dll
rayv
Post by rayv »
thanks
