bpm question
thedave
bpm question
Post by thedave »
not really a bug but this seemed the right place to post.
Is it possible to sync bpm to the timeswitcher overlay so this then operates on the beat rather than sliding up and down to the beat.
Can bpm control a layer filled with jpg's so the picture change happens on the beat?
cheers
dave
VJ304
Post by VJ304 »
You can create new transition bmp. image which all RGB values are at middle, like R 128 G 128 B 128. By using transition image with bpm sync
it changes layers with no sliding.
sami
suvanto
Post by suvanto »
hi,
there is ready made option for that. activate opacity bpm sync and toggle the loop/bounce button next to opacity slider, the third option is the answer.
suvanto
the third option is called min-max, and it,s exactly what you are looking for ;-)
thedave
Post by thedave »
thats perfect, I knew there had to be a way :)
thedave
Post by thedave »
figured out the jpg thing aswell!!!
If you have a layer with x amount of jpgs in it turn on bpm sync on the timeline and change the number of beats to x. voila, 1 image per beat. I LOVE BPM!!!!!!!!!!!!!111111111111111
