Version 7.21.2 rev 37990. When building a WIRE patch and designating a group Name in the Dashboard it doesn't appear in Resolume Arena after compiling. Be cool if it did as it would make things easier to label.
Thanks, Jim
Minor Wire Bug?
Minor Wire Bug?
Jim Branstetter
Alienware M17 R4 RTX 3070 Windoze 11
tijnisfijn
- Team Resolume
Re: Minor Wire Bug?
Hi Jim
After you made a group in wire, you have to drag the parameters that you want to have in this group on top of the group. If there are parameters in the group, then the group will show up in resolume, if there are no parameters in the group, it won't show up either.
Check this movie on 1:09.
Re: Minor Wire Bug?
Doh
, I missed that part, Thank You problem solved.
Jim Branstetter
