If I open Arena and try to open another composition I get the first dialogue and then nothing happens when I click save and open or just open. Just hangs and no option to quit other than force.
If I double click the required comp to open arena it opens my previously used comp.
If I click 'check for update' I get no dialogue.
Version 7.21.1 MBP M2 Max Sonoma 14.5
									Open composition fails, Check for update fails
				Scratchpole
Re: Open composition fails, Check for update fails
Open dialog is opened in another screen. Not sure why this happening, I just use Rectangle app to move window between screens.
				Scratchpole
Just looking at this again, you are correct elgarf, thanks.
I had encountered it before, opening on another screen or behind the GUI but I was in a bit of a rush and didn't remember it this time. It was full screen on start up so they were hidden.
Maybe I had moved those dialogs on to second screen at some point and Arena remembered that?
Seems to be 'fixed' in 7.21.3.
Maybe it's a OS thing, I can't make them open there by moving them there and saving the comp like that....it's odd.
