Active Midi Input Devices preference not saving
Jaymis
Post by Jaymis »
Hi Guys, not sure if this is the intended behaviour or not, but I'm using a BCD2000 and BCR2000 with Bome's Midi Translator and Midi Yoke, so I don't want all of the input devices activated by default. I need to turn off the BCD and BCR and only use the mapped midi outputs from MidiYoke, otherwise I get midi feedback behaviour.
However, each time I restart resolume every midi device becomes active, and turning off the extraneous ones takes quite a bit of time.
It doesn't seem to save this preference in the Midi Settings File. Is that supposed to happen? Is there a way for me choose the default Midi Input Devices?
Cheers. 2.4 is rocking out.
Jaymis
sj1972
Post by sj1972 »
I can confirm this bug/feature...
Steen
syncopated.tv
normal
Post by normal »
Yeah same thing happened to me last night as well.
yes we can confirm this bug, we,ll try to fix it for 2.4 final
[Edited on 18-9-2006 by bart]
