right, have a show this saturday and the desktop I would use for content creation has died, fried the mobo and chip.
So instead of putting together some new clips I thought i would work a little more with effects, not something I have a lot of experience with.
One of my favourites is freeframe fisheye.
add it to a clip
set distortion to bpm - forward - 16beats
(no matter if the bpm is in sync)
set effect opacity to feedback at around 60-70%
tap resync to pop the clip with all the smokey feedback haze
experiment with different settings its fun!
the resync button is great for drumming, especially with semi transparrent global effects
anyway, what are your secrets?
the "share your fx settings" thread
tim.krieger
Hi!
I cant believe no one posted in here..
Well, maybe I can start an avalanche..
I loove the bpm feature combined with the effect parameters..
If you have pete's freeframe plugins, you are probably familar with the half tone or the MetaImage plugin. Both look really cool and dynamic when you sync them to the beat.. gives your old boring footage a whole new edge
hope to hear more from you folks!
Timbo
Timbo
