Convert a normal Input Image to a converted Output Image
BB2901
Post by BB2901 »
Hello everyone,
I would like to add content to an sphere.
But if you output the content unconverted to the sphere, it is distorted on the sphere.
Regards
BB
Scratchpole
Re: Convert a normal Input Image to a converted Output Image on a real LED Videoball (Plugin? Build?)
Post by Scratchpole »
I think this can be built with Wire: 'The To Polar node allows you to convert cartesian coordinates to polar coordinates.'
If you find ISF code, which does this, you can use that in Wire.
tijnisfijn
Post by tijnisfijn »
I think you want something like this... I've sent you a DM.
BB2901
Post by BB2901 »
Thank you very much, Tijn
