Vram usage getting higher and higher.
EBMCreative
Post by EBMCreative »
I have noticed since the newer versions of resolume that the vram usage keeps climbing and doesn't go down when releasing clips.
Is there a memory leak somewhere that is causing it not to release unused memory?
Re: Vram usage getting higher and higher.
Did you send over a log from within Arena? If not, could you do that and also share your hardware info? Thanks
