advanced output slice transitions
jamalofearth
Post by jamalofearth »
hello,
I've searched around for a solution to this but can't find a tutorial on it. Under my advanced output, I have 3 slices in unique shapes that are all calling a single clip on a single layer.
I would like to have the slices transition from one slice to another in the same way clips can transition from one to another. So that it looks like each slice shape is transforming into another.
Might anyone have a solution in mind?
Thank you in advance!
Re: advanced output slice transitions
The most you can get is to fade between slice positions/looks.
In Wire you could create custom shapes and use union or join nodes to morph shapes, then you could assign that as a mask or assign content to each shape.
jamalofearth
Thank you so much. I am studying into this.
Slice transform can be used as effect clip, and you can mix/transition effect clips.
https://resolume.com/support/en/transfo ... -transform
https://resolume.com/support/en/effects#effect-clips
