[fixed] Crash on loading files
x-mode
Post by x-mode »
Hi there,
just downloaded and installed Resolume 2.4 trial. Programm looks great except for the fact I cannot load my own footage into the decks. Everytime I try Resolume crashes. The files do play fine in VLC Player.
Following your Manual "Preparing media" I re-encoded some of my videos with VDubMod to Indeo 5.11 and also Cinepak in 400x300 resolution without audio. The material was originally captured with HuffyUV-Codec, if this does matter.
Operating System: WIN XP Pro
Processor: Mobile Intel Pentium M 725, 1600 MHz (16 x 100)
Videocard: ATI Mobility Radeon 9600 Pro Turbo (Dell)
File type: .avi
Codec: Cinepak
I put up one of the files causing Resolume to crash for download: click here (~4.38mb)
Help appreciated ;)
Regards
x-mode
[Edited on 22-9-2006 by bart]
x-mode
Post by x-mode »
Ooooops...forgotten the logfile:
Logging started: Mittwoch, 20 September 2006 - 18:13
start up 20.09.2006 18:13:22
create my documents folder if not exists for current user 20.09.2006 18:13:22
create application data folder if not exists 20.09.2006 18:13:22
check direct x version 20.09.2006 18:13:22
check if flash is installed and version 20.09.2006 18:13:26
init: previewer 20.09.2006 18:13:30
init: decks 20.09.2006 18:13:30
init: file browser 20.09.2006 18:13:30
init: fx 20.09.2006 18:13:30
init: sources 20.09.2006 18:13:30
init: preferences 20.09.2006 18:13:31
init: shortcuts and midi 20.09.2006 18:13:32
init: recording 20.09.2006 18:13:32
init: audio fft 20.09.2006 18:13:33
init: render 20.09.2006 18:13:33
init: bpm 20.09.2006 18:13:33
init: screensetup 20.09.2006 18:13:33
firsttime get displays 20.09.2006 18:13:33
firsttime copy display setups 20.09.2006 18:13:33
finalize screen setup 20.09.2006 18:13:33
destroy screens 20.09.2006 18:13:33
create screens 20.09.2006 18:13:33
search main dxdraw 20.09.2006 18:13:33
set dxdraw resolumedraw 20.09.2006 18:13:33
position mainscreen 20.09.2006 18:13:33
check for dvdmax 20.09.2006 18:13:33
set global settings for multi and single screen 20.09.2006 18:13:33
initialize all screens 20.09.2006 18:13:33
dualscreen is false 20.09.2006 18:13:33
initialize dxdraw 20.09.2006 18:13:33
--------------begin intialize-------------- 20.09.2006 18:13:33
creating overlay if needed 20.09.2006 18:13:39
create surfaces 20.09.2006 18:13:39
width:320height:240 20.09.2006 18:13:39
create vidnet object 20.09.2006 18:13:39
create spectrum surfaces 20.09.2006 18:13:44
create watermark surface 20.09.2006 18:13:44
create system surfaces 20.09.2006 18:13:44
create system preview surfaces 20.09.2006 18:13:44
create directshow movies 20.09.2006 18:13:44
create vfw movies 20.09.2006 18:13:44
check quicktime and create movies 20.09.2006 18:13:44
check for capture devices 20.09.2006 18:13:44
create dibs for pictures 20.09.2006 18:13:44
create picture objects 20.09.2006 18:13:44
create picture dib objects 20.09.2006 18:13:44
create plugins 20.09.2006 18:13:44
create flash 20.09.2006 18:13:44
again try dvdmax if not created and if supported 20.09.2006 18:13:44
get bltcaps 20.09.2006 18:13:44
--------------end intialize-------------- 20.09.2006 18:13:44
assign additional screens to resolumedraw engine 20.09.2006 18:13:44
position displays 20.09.2006 18:13:44
set screen setups 20.09.2006 18:13:44
start render engine 20.09.2006 18:13:44
render engine started 20.09.2006 18:13:44
init: load startup decks 20.09.2006 18:13:44
getPreview e:\video\cinepak\bubbles.avi 20.09.2006 18:14:01
generate preview from disk e:\video\cinepak\bubbles.avi 20.09.2006 18:14:01
this file crashes resolume here too! Not only 2.4 also 2.3. It,s probably something funny with this file, could you try creating one with premiere or aftereffects?
x-mode
Post by x-mode »
Ehm...nope.
Both Premiere as well as After Effects require heavy investments, too heavy for a try *gg
Well actually I never used either programs....
But, it's not only this file crashing resolume, any of my own files does so.
This is really weird.
Sense
Post by Sense »
VDubMod tend to write headers wrongly, try virtualdub pure and try again.
nz//sense
x-mode
Post by x-mode »
Well, I dled latest VirtualDub 1.4.9.3 VCR + SYNC and retried with that one. After recoding the videofile to Indeo 5.11 Resolume crashed again.
Perhaps it's due to the fact that the video was originally captured with HuffyUV codec? Do higher bitrates (1069 kbps in this case) have any influence?
By the way: I dled After Effects Trial Version in order to try that way. When converting the file to Cinepak with After Effects, the videofile plays in resolume. This seems to be a VDub-problem!
Last but not least: Resolume is a great program! I just recently started with videostuff (after 13 years of DJing), so you can call me kinda noob who hasn't seen much yet but Resolume looks and feels great to me.
[Bearbeitet am 21-9-2006 von x-mode]
