TL_FFGL StarBloom
cisco
TL_FFGL StarBloom
Post by cisco »
Hello, I'm looking to redo an effect that I miss so much. It's TL_FFGL_starbloom, could anyone help me?
Capture d’écran 2024-10-01 à 15.26.47.png (18.22 KiB) Viewed 21423 times
cat
Re: TL_FFGL StarBloom
Post by cat »
Probably worth screen shooting what the output is, so we know what you are looking for
cisco
Post by cisco »
In fact, this effect allows you to create stars with several branches from each hot point (luminous) and to make them explode more or less...
Scratchpole
Post by Scratchpole »
Here's a similar effect made in Wire by Sjan Top: viewtopic.php?t=25207
Here's a version I created (Mac Only) made with Vuo: https://www.dropbox.com/scl/fi/v47592jz ... dry6w&dl=0
MarkyMark
Post by MarkyMark »
Have a look at the Mesh2D tutorial, the Mesh2D templates and the Cloner examples if you want to make something like this yourself.
Scratchpole
Got some feedback from a user and realised the link I shared was an old version of the plugin which no longer works. Have updated the link above to a working version.
