Crashes and Crashes
movebandit
Crashes and Crashes
Post by movebandit »
I had my first Gig with the new 2.4 version. Crashes,Instant Shutdown or Freezes (with a nice bright fullscreen white output) nearly 10 times in the set.Mostly while browsing and loading new Decks.
2.3 and 2.4Beta were much more stable.
Ill post more Details and the Bugs i found later.
richarddesouza
Post by richarddesouza »
glad (kind of) that it's not just me. 2.4 is pretty unusable on my machine.
VJ Nexus
Post by VJ Nexus »
agree - browsing and loading files causes crashes time and time again. It crashes when i open the folder in the browser, but it's not always the same folder. Sometimes it works, sometimes not. Staying with the beta version for now...
Crowny
Post by Crowny »
That's good to know.
Was going to try out the new 2.4 verson this weekend but I might go back to the Beta version until I here a few more reports.
could you please activate logging and send us the file?
here is how to activate logging:
http://www.resolume.com/forum/viewthread.php?tid=2572
nowig
Post by nowig »
on my computer resolume stop craching since i uninstall the other versions of resolume and that my computer run Windows with a DEP exception list on Resolume.
juLiE
yes crashes: logs/details/etc.
Post by juLiE »
(did not have time to post this before gig and still busy for another one soon, so i write this quickly, sorry if not totally clear - still LOVE resolume overall):
2.3 was rock solid for me. 2.4 beta i played w/new stuff, didn't test, only tested w/2.4 final, and yes, unfortunately it crashed/froze/etc.
seems like decks from 2.3 that have *effects* saved in individual channels was my issue. i came across this conclusion based on opening up 2.3 decks in 2.4 F (copied 2.3 decks to appropriate folder in 2.4 F), making changes to them and then saving them and wham bam crash (pgm closes, back to desktop).
also, if i loaded a deck that had no effects in indiv. channels into deck1, then dragged another deck that did have effects in indiv. channels onto the same deck1, resolume crashed again (pgm closes, back to desktop).
(re-edited on 9.26.06 10:37pm - effects are definitely an issue for me in 2.4 F)
i got around this by loading that problem deck (w/effects in indiv. ch.) IN RESOLUME VER. 2.3, removing the effects and opening up same deck in 2.4 and applying the same effects only from 2.4 and saving it - then the above issues no longer applied.
FREEFRAME TIME (effects)
the main effect that seem to blow up resolume was "delay RGB". also, a couple of times "delay mask" crashed it too, but then sometimes it worked fine!
*** LOG FILES ERRORS BELOW ***
ACCESS VIOLATION ERROR MESSAGES IN BOLD BELOW
1 last thing, when you designed 2.4 Beta, your folder for settings was "resolume 2.4", not "resolume 2.4 BETA", so when one installs 2.4 final, it writes over this, and if ones uses 2.4 beta again, it saves over 2.4 final and vise versa (hope this is clear).
sorry, 1 last thing: could you provided us a list of effects that were changed from 2.3 so we can check them on our end to make sure we're using only 2.4 and not 2.3? if time permits? ;-)
RUNTIME ERROR:
runtime error 216 at 00002C48
LOG FILE DETECTS DUPLICATE PLUGGINS:
[i had copied my fx.xml file from 2.3 to 2.4 because i didn't want to have to reprogram the keys again, however, maybe not a good idea especially if you changed 2.3 effects?)
duplicate freeframe pluginkey found: 9/21/2006 3:36:12 PM
key Horizontal Shift same as Horizontal Shift 9/21/2006 3:36:12 PM
key Mixer same as LumaKey 9/21/2006 3:36:12 PM
BIG LOG FILE (SORRY) WHEN HAVING DELAY RGB ISSUE:
Logging started: Thursday, 21 September 2006 - 16:43
start up 9/21/2006 4:43:01 PM
create my documents folder if not exists for current user 9/21/2006 4:43:01 PM
create application data folder if not exists 9/21/2006 4:43:01 PM
check direct x version 9/21/2006 4:43:01 PM
check if flash is installed and version 9/21/2006 4:43:01 PM
init: previewer 9/21/2006 4:43:03 PM
init: decks 9/21/2006 4:43:03 PM
init: file browser 9/21/2006 4:43:03 PM
init: fx 9/21/2006 4:43:03 PM
duplicate freeframe pluginkey found: 9/21/2006 4:43:03 PM
key Horizontal Shift same as Horizontal Shift 9/21/2006 4:43:03 PM
key Mixer same as LumaKey 9/21/2006 4:43:03 PM
init: sources 9/21/2006 4:43:04 PM
init: preferences 9/21/2006 4:43:04 PM
init: shortcuts and midi 9/21/2006 4:43:05 PM
init: recording 9/21/2006 4:43:05 PM
init: audio fft 9/21/2006 4:43:06 PM
init: render 9/21/2006 4:43:06 PM
init: bpm 9/21/2006 4:43:06 PM
init: screensetup 9/21/2006 4:43:06 PM
firsttime get displays 9/21/2006 4:43:06 PM
firsttime copy display setups 9/21/2006 4:43:06 PM
finalize screen setup 9/21/2006 4:43:06 PM
destroy screens 9/21/2006 4:43:06 PM
create screens 9/21/2006 4:43:06 PM
search main dxdraw 9/21/2006 4:43:06 PM
set dxdraw resolumedraw 9/21/2006 4:43:06 PM
position mainscreen 9/21/2006 4:43:06 PM
check for dvdmax 9/21/2006 4:43:06 PM
set global settings for multi and single screen 9/21/2006 4:43:06 PM
initialize all screens 9/21/2006 4:43:06 PM
dualscreen is true 9/21/2006 4:43:06 PM
set device handle 9/21/2006 4:43:06 PM
initialize dxdraw 9/21/2006 4:43:06 PM
--------------begin intialize-------------- 9/21/2006 4:43:06 PM
creating overlay if needed 9/21/2006 4:43:09 PM
create surfaces 9/21/2006 4:43:09 PM
width:400height:300 9/21/2006 4:43:09 PM
create vidnet object 9/21/2006 4:43:09 PM
create spectrum surfaces 9/21/2006 4:43:09 PM
create watermark surface 9/21/2006 4:43:09 PM
create system surfaces 9/21/2006 4:43:09 PM
create system preview surfaces 9/21/2006 4:43:09 PM
create directshow movies 9/21/2006 4:43:09 PM
create vfw movies 9/21/2006 4:43:09 PM
check quicktime and create movies 9/21/2006 4:43:09 PM
check for capture devices 9/21/2006 4:43:09 PM
create dibs for pictures 9/21/2006 4:43:09 PM
create picture objects 9/21/2006 4:43:09 PM
create picture dib objects 9/21/2006 4:43:09 PM
create plugins 9/21/2006 4:43:09 PM
create flash 9/21/2006 4:43:09 PM
again try dvdmax if not created and if supported 9/21/2006 4:43:09 PM
get bltcaps 9/21/2006 4:43:09 PM
--------------end intialize-------------- 9/21/2006 4:43:09 PM
assign additional screens to resolumedraw engine 9/21/2006 4:43:09 PM
position displays 9/21/2006 4:43:09 PM
set screen setups 9/21/2006 4:43:10 PM
start render engine 9/21/2006 4:43:10 PM
render engine started 9/21/2006 4:43:10 PM
init: load startup decks 9/21/2006 4:43:10 PM
Access violation at address 0B80135C. Read of address 0B80135C 9/21/2006 4:46:14 PM
--------------begin finalize-------------- 9/21/2006 4:49:43 PM
deinit effectgenerators 9/21/2006 4:49:43 PM
destroy surfaces 9/21/2006 4:49:43 PM
destroy flash 9/21/2006 4:49:43 PM
destroy directshow movies 9/21/2006 4:49:43 PM
destroy vfw movies 9/21/2006 4:49:43 PM
destroy quicktime movies 9/21/2006 4:49:43 PM
deinit and destroy capture devices 9/21/2006 4:49:43 PM
destroy dibs for pictures 9/21/2006 4:49:43 PM
destroy pictures 9/21/2006 4:49:43 PM
destroy more surfaces 9/21/2006 4:49:43 PM
destroy system surfaces if needed 9/21/2006 4:49:43 PM
destroy system preview surfaces if needed 9/21/2006 4:49:43 PM
destroy overlaysurface if needed 9/21/2006 4:49:43 PM
Logging ended: Thursday, 21 September 2006 - 16:49
[Edited on 25-9-2006 by juLiE]
[Edited on 26-9-2006 by juLiE]
