[confirmed] In/out-points not saved when set by midi controller
Beige
Post by Beige »
Hi, I noticed that when I set in- and out-points on an active layer by midi controllers, they are not saved on the fly to the clip in the deck - they are lost if I switch to another clip and then back. It saves them right when set with mouse, and works fine in v2.3.
Does anyone else have the same problem? Use of in- and outpoints with midi controllers is crucial for me, it's fast and spontaneous way of tuning and scratching clips to music.
[size=-2]Operating System: Windows XP Professional
Processor: Intelcore duo T2300 1.66Ghz 667Mhz FSB
Videocard: Ati Mobility Radeon X1400 256Mb
Midi Keyboard: Edirol PCR-30 via USB[/size]
[Edited on 25-9-2006 by Beige]
[Edited on 27-9-2006 by bart]
Yes confirmed, thanks for letting us know.
i just spend 20 minutes playing with the in and outpoint on midi control, i totally forgot how much fun it is to make my footage twist and jitter with this ;-) awsome ... but indeed after switching back to it, the in and outpoints are reset.
