I've been trying to set up a network between 2 computers using a network cable and the vidnet option. I can see the computer and I can drag it to a deck but I can't get it into a layer. I managed only ones but then I still couldn't see any image.
I'm not a network wisard so there might be some settings I set wrongly. I also tried doing it through firewire as suggested in the manual but couldn't see it at all.
Does anyone else have the same problem or has anybody got some more indepth guidelines how the network should be set up to function properly?
