Storage method
Kenjiro
Storage method
Post by Kenjiro »
Even if I save the show data I created under a different name, it gets overwritten when I create a new one.
Please tell me the basic way to manage show data.
Re: Storage method
Are you doing "Save As..." or rename the compositon and Save?
Kenjiro
Re: Storage method
Post by Kenjiro »
I launch the basic data with basic settings in the documents folder, change the name and save it.
However, doing it this way updates all past show data to the same content.
I'd like to know basic methods of saving and managing data, including managing content.
Re: Storage method
Changing the name in the composition settings doesn't change the file name you work with.
Use Save As to make a different composition file.
