Hi folks, happy Halloween!
A quick patch to add cobwebs to you slice, feel free to add effects(ripple ect.) or change the image to you liking.
If you have a lot of slice, frame rate may drop.
Would like to use Trim instead of Crop, but Trim does not support Instancing. So use this patch with some discretion.
Spiderwall
Spiderwall
- Attachments
Spiderwall.wire- (1.51 MiB) Downloaded 584 times
https://get-juicebar.com/creator/tweelicht #tweelicht_visuals
