one clip two columns long
lamatastisch
Post by lamatastisch »
Hello,
is it possible to play one clip looping over two columns?
Reason for the question: I have 4 screens, on one screen the content should change without interrupting the playback on the others, after that every screen changes together. In the end there show only be one GO button.
tijnisfijn
Re: one clip two columns long
Post by tijnisfijn »
I would copy the clip that you would like to have continuously playing. Then in the clip transport, I would set the first clip to play the first half of the movie(or as long as it needs to played before the other clips needs to skip), and then the second clip to play the second half and in the clip auto pilot of the first clip set it to play next clip. I hope that will solve you problem. If you have any more questions, let me know
lamatastisch
Thanks for your reply!
This won't work out for me, because the timing is not the same everytime (speech).
I think it would be a nice feature to have a clip that is more then one column wide.
tijnisfijn
ok that you could do it like this: copy the clip. Set the second playing clip on playmode relative. Like you see on the picture. Now, you can switch between clip one and two and clip two will continue where clip one used to be. I hope this will help you out.
try to set ignore column trigger on the clip slot you want to have the clip keep playing
https://resolume.com/support/en/clips#i ... mn-trigger
