No LEDs APC Mini Mk2
tmacbusy
Post by tmacbusy »
Hello all,
Recently after doing a clean install of Resolume, I went to map my APC Mini Mk2 shortcuts again and noticed I'm getting no LEDs at all when mapping buttons.
I did follow this video already, https://www.youtube.com/watch?v=zA6D5Gd9Uik, know about drum mode and setting my velocity. Controller is showing as channel 10, but in the MIDI monitor I am not seeing the correct in/out velocities, only 127 and 0 and no illumination at all on the controller. Running 7.21.3.
Thanks in advance!
Christoph
Re: No LEDs APC Mini Mk2
Post by Christoph »
As Sean mentions in the video description, the steps from that video are obsolete and not necessary since Resolume 7.17, so if you are running 7.21.3 this should work without putting your controller in drum-mode.
Have you tried to just plug in and map with the default channel 1?
