Clip - BPM Sync - shift starting point
chq
Post by chq »
is it possible, to move/shift the starting point of a clip?
it don't want to move in- or out-points or click on RESYNC; only the starting point inside the content of a specific clip should be shifted.
For example a clip with a jumping rabbit is running with BPM sync and the rabbit is not jumping at the beat syncs clock, only delayed, so i would like to move the clip framewise inside his loop to adjust so that the rabbit jumps to the beat sync.
Greetz Chris
mowgli
Re: Clip - BPM Sync - shift starting point
Post by mowgli »
Not exactly what you describe but you can use cuepoints to achieve a similar thing.
