When creating a new advanced (virtual) output I am always slightly annoyed when I use tab to move from width input field to the height input field and it goes to who knows where?
If you don't change the width parameter it does tab to the next field correctly, but if you change width and then tab to go to height field the cursor disappears.
Been the same on Mac and Windows for many many versions.
Advanced output, tab to next field issue
Scratchpole
Scratchpole
Re: Advanced output, tab to next field issue
Tumblweed.
Does nobody else experience this?
I know it's a small bug, but it is persistent.
Most of us use the space bar method.
Example Slice: x:0 , y:0 , w:200, h:400
0 [space] 0 [space] 200 [space] 400 [enter]
Scratchpole
I am talking about the size of the screen/virtual output, not a slice. You don't answer my question about whether you see this bug too.
Also, your false authority when you talk about 'most of us' smacks of an ego the size of a bus. Just lettiung you know.
No ego here, but I'll let you figure this one out without me.
