Wrong clip target in 7.22.x
I use "Active layer" as default Clip Target in composition. Since 7.22, when I click in a clip that is BPM synched, it goes to his own layer, instead of active one. A workaround for this is to set composition's beat snap to "none", but it makes the clips go out of sync.
tijnisfijn
- Team Resolume
Re: Wrong clip target in 7.22.x
Thanks for bringing this to our attention! You’re absolutely right—there’s a bug in Resolume 7.22 that’s causing BPM-synced clips to ignore the "Active Layer" Clip Target setting when Beat Snap is on.
We’ll be looking into it. Hopefully, we can fix it in a future update!
Thanks again for reporting this and helping us make Resolume better. If you have any more questions, feel free to reach out!
