sync multiprojection
stl
Post by stl »
Anyone know a software that do the sync between 3 computers?
I have an installation with 3 sync screens and i will use 3 computers. Anyone know any software that make the sync by Ethernet (by ip)? Client and server mode? I found some max msp patch but only with 320x288 and i will need something similar with PAL (720x576).
you can sync multiple computers with Resolume using the bpm clock. Simply send a midi clock signal to all computers using Resolume and set your clips to bpm mode. This way your clips in different computers are perfectly in sync. Checkout http://www.eyesupply.tv/site/projects/p ... terdam.htm this live projections was done with Resolume with the bpm clock.
