Beat Snap broken in 7.22.2?
mfo
Post by mfo »
I might overlook something, but it seems that in the latest release the Beat Snapping is broken.
Videos with an audio-track always always always get the little indicator (a T in a circle) and delay the clip-start to beats/bars.
In my case: Beat Snap is set to "Composition Determined" and in the composition is set to none. Even if I set Beat Snap individually to "none", still, the clip-start is not immidiate, rather snaps to beats/bars.
tijnisfijn
Re: Beat Snap broken in 7.22.2?
Post by tijnisfijn »
Thank for reporting this, we had somebody else also reporting this issue and we are investigating it. There seems to be something strange here as far as we can tell now it's only when clips have a audio track. It clips are just video. They work fine.
mfo
Post by mfo »
Yep, can confirm that. Non-audio-track clips work as expected.
mfo
Post by mfo »
Bug is still there (7.22.3).
Just sio it's not forgotten :)
(it is actually a medium-big problem for ome recent project)
Christoph
Post by Christoph »
The "T" in a circle would indicate a transition going on, not beat snap.
Could you attach a composition file where this happens for you (or send it to mail@resolume.com)?
mfo
Post by mfo »
Oh shuut! Ok, I'm so sorry. It seemed to be waiting for beat snapping (accidentally I had the perfect transition length..) and the spinning animation looked like the bpm animation. But indeed, it was simply blending-in/transitioning! Most of my clips start black (black frames in beginning), so I just assumed they all start delayed.
This new feature perfectly bamboozled me.
Maybe a feature request then? Change Transition indicator animation to a rising vertical bar on the right side of the thumb - as this is the way the transtion controls fader is situated.
Christoph
Post by Christoph »
Alright, good to know that this is not actually broken. There was another issue with beat snap with 7.22.2 but this should be fixed since 7.22.3!
We know that the different indicator countdowns (beat snap / autopilot / transition) can be a bit confusing in some scenarios, we got a ticket for this!
