Building the Pixel Powerhouse: Advice Wanted Before We Blow the Budget
Abhi3626
Post by Abhi3626 »
Hello Pixel Lovers,
We’re looking to build a system with three 4K outputs and one for the Resolume UI. Below is the list we’ve put together. This same desktop will also run three different real-time software applications using NDI and SPOUT for input and output. Any advice would be greatly appreciated! :geek:
CPU: AMD Ryzen™ 5 9600X, 3.9 - 5.4GHz, 6 cores
GPU: NVIDIA® GeForce RTX™ 4080 SUPER, 16GB GDDR6X
Motherboard: ASUS TUF GAMING X870-PLUS WIFI
RAM: 64GB DDR5 8000MHz T-Force XTREEM ARGB (4x 16GB)
Primary Storage: 1TB SAMSUNG 990 PRO NVMe SSD (Gen 4)
Secondary Storage: 2TB SAMSUNG 990 PRO NVMe SSD (Gen 4)
Operating System: Windows 11 Professional
He2neg
Re: Building the Pixel Powerhouse: Advice Wanted Before We Blow the Budget
Post by He2neg »
My advice atm,
if you can wait for the next geforce 50XX generation do this ;)
~Berlin~
