wanted to add a couple of things I feel are still needed on resolume to have optimal BPM integration
(already mentioned in other posts)
LFO synchronized to bpm.. so that the speed of the movement between min und max values is not linear, but maybe exponetial or "log" or whatever option comes to mind
display BMP all the time
some new ideas:
speed control using bpm, so that the clip speeds up or down on beat and then loops or bounces.. (all the normal bpm things resolume has for other controls)
limit BPM movement on Opacity control, and the above mentioned speed control (limit is currently available for the clip's playhead and for effect parameters)
add beat offset to BPM options... in adition to the normal Beat number... (also usable for the suggested non-linear BPM (LFO mode))
bpm offset explained: (+ is maximum value und - minimum, 0 offset is the only current state possible)
BPM improvements
stanleystark
BPM improvements
- Attachments
- offsetEX1.JPG (34.53 KiB) Viewed 6839 times
stanleystark
stanleystark
