Black Screen Issue in Resolume Arena – Need Help!
romillyrom
Post by romillyrom »
Hi everyone,
Iam having trouble with a black screen in Resolume Arena. The software launches fine, but when I play a clip or send visuals to my projector, the output is just black.
I have checked all the hardware connections (HDMI, projector, etc.), updated my graphics drivers, and confirmed the projector works with other devices. Iam running Resolume Arena .
Could this be a problem with the output settings or my composition setup? If anyone has experienced this and found a fix, I would love to hear your advice. Thanks!
Christoph
Re: Black Screen Issue in Resolume Arena – Need Help!
Post by Christoph »
I assume you have your projector set up as an extended screen and you can see images from your computer (e.g. your desktop background) there?
From Resolume have you activated 'Fullscreen Output' or 'Advanced Output' to your projector?
Make sure your composition and layer master slider and video opacity sliders are at 100%
Does your machine meet our minimum system requirements?
https://resolume.com/support/en/tech-specs
If the issue persists maybe you can attach some screenshots of your composition user interface screen and your output setup?
