Audio effects what do you recommend?
oefu
Post by oefu »
I'm wondering what other people use and recommend as audio effects in Resolume. Are there any good VST effects that are worth the time and money or should I bother learning Ableton and putting the audio effects in there? Does Resolume Wire support VST effects?
mowgli
Re: Audio effects what do you recommend?
Post by mowgli »
It depends what you want to do.
I use VSTs in Resolume for a variety of projects including this:
oefu
Post by oefu »
mowgli wrote: Wed Jan 22, 2025 22:03 It depends what you want to do.
Thank you very much for the tutorial!
oefu
Post by oefu »
AlfredaWeimann wrote: Fri Feb 21, 2025 02:47 You can consider using FabFilter Pro-Q, it provides a powerful EQ, suitable for fine-tuning the sound.
Currently, Resolume Wire does not directly support VST plugins. But you can use Wire to create custom effects and video sources as you like.
thank you for the tip!
