I haven't made any changes to my system, but trying to open Avenue (v7.19.2) and I keep getting the same message.
Any advice?
MBP 2018 (os12.7.5)
Avenue Quit Unexpectedly - LOOP!
tijnisfijn
- Team Resolume
Re: Avenue Quit Unexpectedly - LOOP!
You can start with moving your last use composition from your composition folder if you're not sure which one just moved the complete folder to check if that makes any difference if that doesn't make a difference, you can also try to move your complete avenue documents folder temporary to a different location and see if that fixes it.
Let me know if that works for you
Thanks - moving the whole folder worked - a report has been sent!
Thanks for the report /Library/Audio/Plug-Ins/VST/Relab Development/LX480 Essentials.vst is crashing on load.
Try removing it from the plugin paths.
I've moved the whole folder and it works. Thanks.
Thanks for the suggestion. Can you advise how to identify if a new plugin will cause problems in advance of putting it in a folder with others that do work?
In advance?
no,
try it out, and check the logs if stuff fails.
https://resolume.com/support/en/directo ... #log-files
no,
