Feature request:
Mask layers in a group effect options...
- 1 below
- within group
- all below (outside of group)
This feature would be helpful for those who use masking as an effect and therefore put their mask layers within their effect groups
Mask Layers
- rawdesigns
Re: Mask Layers
Group layers can't affect layers outside, they are on a separate render order, think of a group like a sub composition.
The other options should work, and if you want to affect layers outside, you can use the group as mask, setting the group's blend mode to multiply or 50mask.
