Hey Folks,
right now I am replacing some of my produced clips in my main composition with never versions of them. My old Clips are 1920x1080@25 ...the new versions are 3840x2160@60
I am going to replace round a bound 200 Clips.
My old clips in the comp are beat-matched and some of them are scaled and re-positioned. Is there a ways to replace the old Clips without breaking the configuration of them?
best wishes
Replacing Clips with another Version of it
Do you like outlines? Easy Outliner on Juicebar -
tijnisfijn
- Team Resolume
Re: Replacing Clips with another Version of it
If you would call all your new movies the same and that move your old movies to a different location. If you then restart Resolume, it can't find your movies and you can relocate them. If you than replace them with the new movies, it will keep all the settings the original movies had. I'm not sure if it will automatically replace all the 200 movies but this way will for sure be quicker as having to set them up all from scratch.
thanks for your answer... and "Oh" I should have mentioned that I tried that. The problem are the settings I gave the old versions.... they are based on a smaller resolution and another framerate. So, nothing fits anymore
tijnisfijn
- Team Resolume
Then I don't think that there is a out of the box solution for this. Something that you could maybe try, but is definitely not a officially supported way of doing this, open your composition in ChatGPT or Claude or something similar and then try to let them change the file names and do the math to take into account the difference resolution and frame rate.
tijnisfijn
- Team Resolume
I've sent you a DM
