Fixtures in Z axis
vjxrat
Fixtures in Z axis
Post by vjxrat »
I would like to request the possibility of creating in the depth of the z axis, so I can generate fixtures on that axis and be able to make volumetric mappings directly from Resolume and not have to use Touch Designer to be able to work with this new wave of volumetric LED strips.
I understand that to implement this feature, you must first be able to work within the composition using Z-space and use content that works in 3D or at least moves along all three axes.
Is this too much?
thanks
