Wire patch with ISF node image input causing crash in 7.22.5
moldybeats
Post by moldybeats »
Since upgrading to 7.22.5, it seems like any Wire patch that uses an ISF node with an image input causes Avenue to crash when loading the patch.
I can reproduce this on 2 machines (both macOS) using the simplest possible patch: an image node into the "default" ISF node (ie. the shader that gets created by the New command in the node controls) into Texture Out. I verified that an ISF node with no image input works fine. Also, things work fine in Wire itself, it's only when loading the patch in Avenue that the crash occurs. I submitted a crash log over the weekend.
Anyone else running into this, or just me?
Re: Wire patch with ISF node image input causing crash in 7.22.5
Interesting, thanks, for letting us know!
I also see your crash report in the inbox, it will be helpful.
We'll see what we can do.
moldybeats
Turns out this is even simpler than I thought, and doesn't have anything to do with ISF. I can reproduce the crash described above with an Image node plugged directly into Texture Out.
