When I edit a isf, any hooked up parameters while still looking connected, now don't work, and the input value on the isf become visible, even adding a space, ie on every recompile this happens
Just test on a new patch, when I created the patch, the connections from the previous patch remain in the editor
On making a new isf, new default isf, added a color input multiplied with the input image in the isf, works as expected, added a space, and input stops
Editing ISF loses parameters
- Attachments
- Bug.zip
- (2.68 KiB) Downloaded 662 times
- wire2.png (10.77 KiB) Viewed 15663 times
Re: Editing ISF loses parameters
As another note, the same thing happens if its a live effect in arena, as soon as the shader recompiles, it looses the parameters. This is not a good, live coding was a good thing...
Thanks for letting us know, we'll see what we can do about this.
