compositions with wire patch crashes avenue
tfrank
Post by tfrank »
So, i Built a patch with wire. everything running fine and smooth. me happy. I quit avenue, shut down computer. the next time i startup avenue, the programm crashes immediately upon startup. i find out: it is the last composition. so.. i take the composition out of the folder "compositions", startup avenue anew. everything is fine. then i try to load the composition with my wire patch and bang – avenue crashes.
it basically means: i cannot save any composition with the wire patch. which is crazy, because i will need it for a live gig.
what can i do?
tfrank
Re: compositions with wire patch crashes avenue
Post by tfrank »
Hi everyone, I found the problem. Had been playing around with external plugins from other users via juicer, which never downloaded in the end. but there were some links and theses caused the problems. deinstalled all other plugins, deinstalled juicebar. Everything working again.
