Hello everyone out there, are you all still here?
Then I might have something here for you, especially those who don't have a Wire license, but it might be interesting for all too.
I recently & right now modified a Wire example a bit, mainly unlocking options for Arena and Avenue, but also slightly expanding the whole thing. I would also like to extend my sincere thanks to the author of the original example, "Darien Brito"!
& I'm making this Arena/Avenue plugin available here for free download under a CCO license.
The plugin is 4K and should be 1080p compatible. I created it in version 7.18.1, where it runs perfectly. Feel free to post information about how it works in other versions, thanks.
A very brief guide or beter such an option description is available as a PDF in the provided ZIP file here.
The plugin itself can/must be downloaded separately here.
I hope you like my adaptation and no one is upset. If something doesn't work or delike, just leave a message here and I'll see what I can do.
And if you have Wire or want to conjure it direkt into Arena via the free ISF desktop editor (https://isf.vidvox.net/desktop-editor/) such as his Spout/Shyphon sender, here is the link to my latest free to DL ISF shader under an MIT license so that you can use it at events as you please. It was created using ChatGPT, so my many thanks go's to OpenAI.
https://editor.isf.video/shaders/681b23 ... 001a373c17
But now,
with best greetings from the mountainous Switzerland your bennoH.
& don't forget "code kills VideoLoops"!
(My original German text is binding)
------------ German orig. text: ------------
Hallo Ihr da drausen seit Ihr alle noch da?
Dan habe ich hier vieleicht etwas für Euch insbesondere die welche keine Wirelizenz besitzen, aber allenfalls auch für diese interessant.
Ich habe vorhin mal wieder ein in Wire enthalternes Beispiel etwas modifiziert, vor allem Optionen für Arena und Avenue frei gelegt aber das ganze auch leicht erweitert. Herzlichst bedanken möchte ich mich auch sogleich bei dem Autor des Originalbeispiels "Darien Brito"!
Ich stelle dieses Arena/Avenue Plugin kostenfrei unter einer CCO-Lizenz hier zum freien DL ein.
Das Plugin ist 4K und sollte 1080p kompatiebel sein, ich habe es in der Version 7.18.1 erstellt wo es einwandfrei lauffähig ist, wie sich dass mit anderern Versionen verhält könnt Ihr hier geren als Info posten, danke.
Eine sehr knappe kurze Anleitung respecktive ein solcher Optionsbeschrieb liegt als PDF in der bereitgestellten ZIP hier zum DL vor.
Das Plugin selbst kann/muss seperat herunter geladen werden hier.
Ich hoffe meine Adapption gefällt und niemand ist verärgert, sollte etwas nicht passen hinterlegt einfach eine entsprechende Nachricht hier und ich sehe was sich machen läst.
Und wer Wire hatt oder direkt via dem kostenfreien ISF-Desktopeditor (https://isf.vidvox.net/desktop-editor/) dessen Spout/Shyphon den in Arena reinzaubern möchte hier noch der Link zu meinem neusten ISF-Shader unetr einer MIT-Lizenz damit man diesen auch an Events nutzen kann nach Lust und Laune.
Erstellt wurde er mitels ChatGPT also besten Dank an OpenAI.
Zum kostenfreien ISF-DL:
Aber nun wirklich,
schöne Grüsse aus der bergigen Schweiz euer bennoH.
& vergest nicht "Code kill's VideoLoops"!
1 free Arena/Avenue Plugin (as CCO)
- Attachments
- miniManual -NeonCircuits Pro by bennoH.zip
- (104.84 KiB) Downloaded 750 times
NeonCircuits Pro by bennoH.cwired- (416.92 KiB) Downloaded 838 times
