Midi shortcuts
elbundlo
Midi shortcuts
Post by elbundlo »
Hey Resolume!
I just found an annoying bug.
In midi shortcuts, I found that if you have put a midi shortcut on the composition tab, which you might do (as I did) as it is above the composition master fader, when you try and clear it as a shortcut, it is not possible to do so.
I have just done this. I also had the composition master fader mapped to the same midi channel, which made Resolume crash. The only way out was to map the composition tab to another midi note.
Maybe on the next update the composition tab should not be available to map to midi? I for one cannot think of a use for this in the midi mapping.
Apart from that, keep up the good work, you are marvelous!
Cheers,
Paddy
Re: Midi shortcuts
What do you mean map the "composition tab"?
Which UI element is that?
elbundlo
Re: Midi shortcuts
Post by elbundlo »
Hi Zoltan,
I have Resolume open right now and it is the tab that is marked "Composition", top left of the screen. If you left click on it, it does nothing. If you right click, it opens up the same menu as "Composition" which is in the main tab, after "Arena" and before "Deck". It is directly above the X, B, Master opacity fader and s.
I have just managed to erase it now with the delete/backspace key on my laptop.
Problem solved.
Cheers,
Paddy
