Resolume 2.41 update
Sometimes you just need to enjoy the finer things in life, like listening to Ricardo Villalobos instead of Jeff Mills or to Belle & Sebastian instead of Body Count. Drink a nice Merlot instead of cheap Lambrusco. Subtle differences make all the difference ;-)
Resolume version 2.41 does not add any grand blow-your-pants-features but makes your life just that little bit more enjoyable by being more stable, a little faster, a little nicer.
So go ahead and download, it's a free update again!
Change log for Resolume 2.41
friedrich
Post by friedrich »
hope its more stable now. now im away for testing. ;-)
we hope so too ;-)
let us know!
movebandit
Post by movebandit »
YES ! That is the message i was waiting for in the last months....
I´ll do a check next weekend.....
Thanks.......
Maze
RTV
Post by RTV »
if i update all my recorded clips from previous resolume will be deleted? or will be fine?
edwin
Post by edwin »
they will be fine.
gpvillamil
Post by gpvillamil »
I notice that the 2.41 update installs in a new folder, so I then have to move over all my freeframes, decks, etc.
Is it possible to specify the existing Resolume 2.4 directory as the install target, in which case it keeps the existing settings?
Basic
Post by Basic »
can wait to check it out! thanks gents!
We install all resolume versions in different folders so you can always use an older version if you run into problems. You do not have to copy your decks and preferences as they are stored in ~/My Documents/ but you do need to copy your plugins.
Friggin Merlot
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/C_vGuWYZF2U"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/C_vGuWYZF2U" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
My friend Thomas send me this video in reply to our version 2.41 announcement.
If you have not seen Sideways then ... well you should ;-)
