Broken Example Patch - NeonCircuits
moldybeats
Post by moldybeats »
I happened to notice the NeonCircuits example patch in the latest version of Wire (7.22.9) is broken by default. Opening the patch shows the message "An OpenGL error occurred (invalid framebuffer operation)" repeatedly in the Log window. This is on a Mac (macOS 15.4, M2 Max chip).
Changing the Blend Mode of the 2D Render node fixes things, and either blend mode works after you change it.
Re: Broken Example Patch - NeonCircuits
Thanks for letting us know!
