Hello everyone
If I'd known beforehand how easy it is to work with Avenue, I could have saved myself a lot of money.
I've been the proud owner for three months now and I don't regret it for a second.
I've gotten pretty comfortable with it, and now I'm coming to my question.
I've integrated many cameras via Avenue, use a lot of effects, videos, and NDI, and stream via OBS on various platforms.
Now I'm switching, let's say, from Scene 1 to 2 (OBS), but I want Avenue to switch from Compos 1 to Compos 2 at the same time.
Is there any way to do this, e.g., with the Streamdeck via MIDI or via WebSocket? It would be cool if (for example, if the OBS autoswitcher is active) a Compos switch could also take place when changing scenes.
I hope I expressed myself well and Google Translate did a good job.
Best regards from Berlin
Switching Scenes and Compos in Avenue Simultaneously with OBS
- Team Resolume
Re: Switching Scenes and Compos in Avenue Simultaneously with OBS
If you mean, loading a new composition, I think that's only possible through the rest API. But unfortunately, thats a arena only function. But I'm not sure if that's really what you want because that always takes a bit of time. Maybe you can make different decks so you can switch decks and instead of compositions.
Yes, it's possible! You can sync OBS scene switches with Avenue compositions using a Stream Deck with MIDI or WebSocket support. Tools like Touch Portal, Companion (by Bitfocus), or custom OBS scripts (like obs-websocket) can send MIDI or OSC commands to Avenue. This way, changing a scene in OBS can trigger a Compos change in Avenue automatically.exelbonsai wrote: Thu Jun 05, 2025 17:41 Hello everyone
